26th July 2010, 23:03
#1
I don't sniff my cats.
Vehicle: 1994 3.0 SSR-X Copper SV1000S and a Hyundai i10 Drift Car
3.0L Thermostat
Toyota missed an opportunity here.
With a bit of fancy engineering and some lateral thinking, I reckon they could have made changing the thermostat just a wee bit more awkward.
26th July 2010, 23:10
#2
Contributor
Vehicle: KZN130
Which is just what I thought when I thought about doing a full rad flush with a hose on Sunday.
Do you need to pull the stat to do it or is there another easier way with a 3litre? Most of the guides I read on here discuss removing the stat and sticking a hose in.
__________________
Specialisation is for insects
26th July 2010, 23:14
#3
To get a decent flow to flush properly, I think it needs to be pulled.
26th July 2010, 23:20
#4
Contributor
Vehicle: KZN130
Damn it, thought you might say that. Thank you.
__________________
26th July 2010, 23:41
#5
cymru am byth
Vehicle: 200Tdi Discovery
i was looking at mine, even with the head off, aircon off and alternator off, the bottom of the pipe is still attached by bolts that i cannt see as they are still buried under a load of mud  they couldn't possibly make it any harder if they tried.
__________________
Surf. gone but not forgotten
27th July 2010, 06:37
#6
Essex Boy
Vehicle: 2.4 TD 1993 / 3.0 '95 project
Think Vauxhall trumps Toyota on the 1.2 corsa - Cambelt off to access.
31st July 2010, 19:48
#7
Registered User
Vehicle: Surf 3.0 Lt SSRX turbo deisel LTD edition
It's a toss-up between the starter motor, thermostat and EGR pipework, anything else I've found easy/normal/usual garbage, mind I haven't had the good fortune of the bottom end yet, I'll scrap it if there's another big problem though, too old for all this $hit I want to drive not fiddle with poxy jap engineering. H
2nd August 2010, 18:22
#8
Registered User
Vehicle: 1995 3.0L SSRX
Changed my stat a few weeks ago. Taking the old one out was a lot easier than it looked. Putting everything back together again was a different matter and turned out to be a bit of a pain as the stat kept dropping out of the recessed hole in the block. Trying to keep the stat in situ whilst replacing the housing and inserting the two bolts - all with one hand - was a work of art. I'm sure things would have been a lot easier if the size of my hands had been more like the Japanese variety.
Alan
__________________
If at first you don't succeed,
Destroy all evidence that you even tried.
2nd August 2010, 18:52
#9
Super Moderator
Vehicle: 81' V8 Pickup, 94' 3.0TD Surf, 84' 2.0 4Runner, loads of other junk.......
Everything thats a pain in the butt on a 2.4 is easy on a 3.0, inc the starter!
If a stat thats tricky to reach is the trade off, I'm more than happy.
(do it from underneath, tisn't so bad.)
__________________
4x4toys.co.uk - back in business... :-)
| Thread Tools |
| Display Modes |
Linear Mode
You may post new threads
You may post replies
You may post attachments
You may edit your posts
HTML code is Off
vB code is On
Smilies are On
[IMG] code is On
Copyright 2004 the webmaster
Address - N White, PO Box 278 Stevenage, Herts, SG1 1ZU, UK
All information and images on this website
remain the property of the owner and no use shall be made of them elsewhere
in whatever format without the express permission of the owner. All
Corporate trademarks are the property of their respective owners.
You may freely link to this website however ownership of material remains as
stated above.
Contact us:
toyota@hiluxsurf.co.uk
