3rd November 2005, 10:10
#1
Cabin air filter? Where?
Hi can anyone tell me where the cabin air filter is? Had a quick look round but seem to have overlooked it!
Cheers Tom
3rd November 2005, 10:20
#2
Veggie burner since 2003
Vehicle: '96 3.0 SSR-G TurboVeg
Quote:
Cheers Tom
What Cabin air filter??? I don't believe any Surfs have em, except perhaps those with the optional box in the centre of the roof.
Maurice
3rd November 2005, 10:23
#3
Quote:
Really? so the air is just direct from outside?
3rd November 2005, 11:27
#4
Vehicle: FJ Cruiser - Tonka Yellow
Its behind the glove box... but when you see it, you won't call it an air filter... more like a manky piece of foam...
If you remove the glove box, you will have easy access to it... very carefully remove it, and wash it in warm slightly soapy water... and dry it very carefully, not much heat... then spray with those odour spray things that are going around at the moment... (Fabreeze...?)
As for the one in the roof... good luck with that. Its a paper element in a plastic cartridge... no part numbers, no description... Tried to bodge a new element after breaking the plastic cartridge apart... does work after a fashion.. but the rattling fan is driving me nuts...
3rd November 2005, 11:35
#5
Senior member
Yep, or recirculating from interior depending on vent position. The only foam on mine is the seals for the individual vents. This is all rotten and I have the dash in a thousand pieces at the moment repairing them all with new stuff. A job you would not enjoy. If you start removing stuff the seals will turn to dust as soon as you touch them.
Neville
3rd November 2005, 20:09
#6
Vehicle: ssr g 3.0 td 96
Cheers Tom
Hi,
Howard Hughes rides again, eh ? Like it, cabin filters hahahahahahahaha ! still if u live in cumbria maybe u need them, wherabouts are u, i used to repair boats in a big shed near whitehaven, lived in lorton...edge of lake d..
peter
4th November 2005, 10:29
#7
Quote:
Originally Posted by Uplander
Hi,
peter
Hi Peter I basically live in Whitehaven! You need an air filter round here thats for sure. The fan does not seem that powerful so I thought it was blocked with 12 years of dirt!
| Thread Tools |
| Display Modes |
Linear Mode
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
All information and images on this website
remain the property of the owner and no use shall be made of them elsewhere
in whatever format without the express permission of the owner. All
Corporate trademarks are the property of their respective owners.
You may freely link to this website however ownership of material remains as
stated above.
Contact us:
toyota@hiluxsurf.co.uk
