Home Rules Chat Shop Rigs Gallery Files Surf FAQ
Old 6th February 2006, 04:33   #1
baroq
Vehicle: hilux surf,2L-TE
Default engine swap 2L-TE to 1KZ-TE
Can anyone help? i got a 1993 hilux surf with 2L-TE engine. My problem is hardstarting and white smoke coming out on the exhaust.I have brought it to 2 mechanic and both suggested of engine overhaul because of busted piston rings.Did anyone of you encountered same problem?what could be the cause? i have read many feedbacks on 2L-TE engine like crack cylinder head. Right now im considering of an engine swap to 1KZ-TE instead of rebuilding the engine,has anyone tried the engine swap? can you give me feedbacks? will my old tranny on my 2L-TE fit to 1KZ-TE engine?
baroq is offline   Reply With Quote
Old 6th February 2006, 12:02   #2
Blizzard
Vehicle: 94' Toyota 4Runner 3.0 TD
I've a friend with an ex 2-LT now 1KZ-T 4Runner. The swap is pretty easy.
The only problem is your diffs are 4.56 and the 1KZ-T ones are 4.11 or 4.30 (Talking about M/T), but it's easy to solve, put some 33's under it and you'll be done.
David
Blizzard is offline   Reply With Quote
Old 6th February 2006, 12:30   #3
marky
marky's Avatar
Vehicle: ALFA 155
Its not as straightforward as you would think! Wiring loom has differences also ECU & other bits.
marky is offline   Reply With Quote
Old 7th February 2006, 08:01   #4
Blizzard
You've the E versions of each engine. In Spain we have the 1KZ-T in 4Runners or the 2L-T, not the 1KZ-TE, who was only in the Land Cruiser 90/95.
Also we don't have EGR's hehehe.
David
Old 7th February 2006, 09:47   #5
NiftyNev
Senior member
2L-TE to 1 KZ-TE is a huge job that very few have done. It's possible but most forget the idea after they find out what needs to be done. You will need the entire wiring loom ECU and other bits. New engine mountings need to be made as well.
Old 7th February 2006, 10:16   #6
baroq
Well i guess thats one big problem, the ECU .Perhaps i may consider a 3L engine? just to go away with it.
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is it possible engine swap out suga General 5 31st May 2005 23:48
1984 Engine Swap shawns surf 2.4 & 2.8 4 22nd February 2004 11:47
engine swap freeman Technical - Mechanical - General 3 13th February 2004 21:23
engine swap freeman 2.4 & 2.8 2 7th February 2004 21:26
engine swap 3.0td patzx12 3.0 Turbo Diesel 3 17th September 2003 08:31
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
