Nothing better to do so i'm going to write this mod up as i go, might be of help to someone, thought of fitting a twin tank system a while back and have been reading up on it with a lot more reading to do, the rough drawing below is what i had in mind but as i dont seem to plan bugger all properly i expect there'll be some changes as i go along, the idea is to take a hot water supply (probably from the heater) and feed it to an electric pump (already fitted and wired), from there to a heat exchanger and on to the "veg oil" tank running through a coil to help heat the oil in there, the return will then pass through a radiator and back to the heater circuit? the reason for the rad is to help with the trucks high running temps (around 90c+) this may help a bit along with changeing the viscious fan for electric at a later date.
I did'nt want to fit the veg tank in the load space for obvious reasions so the only other place was where the spare wheel used to be, i'd already removed the wheel cradles and winch stuff so it was nice and clear, had a quick measure up and started looking on ebay, if you "well off" you can have a tailor made tank knocked up but as i intend doing this as cheap as possible it's going to be a second hand one for me, found the very item and got it for £35 (plus £35 in diesel go get it, but we wont mention that) it's a land rover 90/110 80 lt defender (andy informs me) tank and once the waxoil had been washed off it was like new, came with a brand new sender unit too, first pics are a test fit on a jack and it fitted up there very nicely, it dose'nt hang too low, could have got away with a wider tank but 80lt is enough range for me i think,
First step was to make some form of fixeing to hold it, again andy informed me that the holes back and front in the seam are not man enough to support a full tank so straps were needed, i did however use the two holes at the back to locate the tank on, this is to stop the thing moveing about in it's straps and does not support it, i drilled the tow bar cross member and fitted some theaded rod with rubber bump stops, large flat washers and nyloc nuts,
with the tank located on these i could then jack it up into position and see what was what, decieded to use two 30mm X 6mm flat bar bolted to the chassi Xmember,this should support the tank OK, i could then make the straps,
i used some 30mm X 3mm flat bar (from B&Q) bent to shape and drilled, threaded rod is used to join the lot together, the pic shows them without the tank in place,
But before i fit it it'll need some work to take the coil and a temp sender,
also i need to fit the radiator while i can still get in there,
but it's got a good flow rate and have to get it nickle plated yet, till then i'm stuck,
BTW these were courtest of MattF, i did'nt know they were "blinking" leds till i wired em up, nice one, switch for the pollok valve is up there to with of course leds to show which tank i'm on.
, and hand over to the master.
