3rd gen Winch Bumper
  • 3rd gen Winch Bumper
    Been busy this weekend making a bumper for my 3rd gen. All built and designed by myself. i know the welding ain't great but it will do what it's suppose to do. What do you guys think! I'm well pleased with it as have never really worked with metal, only other time was when i was at school.
    Standard bumper removed
    Templated up (yes i know theres only half a template lol)
    Winch plate made up
    Bumper parts cut
    Bumper made up
    Priming up
    Once it's all paint up i'll put up a pic of the finish product.
    This is just an observation not a criticism but will it not restrict air flow to the bottom of rad.
      not really as the bottom part of the rad is uncovered plus the top section.
        plus forgot to say that i still need to put the fog, spots and indicators in.
          Righto, to say you've never done it before it looks a very neat & tidy fit.
            I had the same thought about the air restriction, but maybe its just the angle of the pics. Could you incorporate a low baffle into the design to help push the air up to the rad if necessary...?
            And as for not being that good, if all the things I wasn't 100% on were that good, I'd be pretty chuffed!!!! nice work.
            www.johnthebuilder.info
              Nice work mate, love to see shed built, it's the only way.
              Are you returning the bumper at an angle underneath?
              Did you cut the sheet with a plasma?
              Brian
                it is slighty angled underneath i'll take a pic tomorrow to show ya. as for plasma cutting nope, all done via jigsaw lol.
                  Jigsaw nice, how thick is that sheet 2mm or 3mm? What jig blades did you use and how well did they last?
                  I take it the brackets are 6mm or there abouts?
                  Brian
                    the blades are dewalt cuts between 2.5 and 6mm easy. for all the cuts i used 2 blades. the sheet is 2.5, the angel is 5mm, the plate is 6 and the upright supports are 4mm.
                      final product. all that is left is to cut holes for spots, fogs and indicators.
                      i think it looks wicked!
                        very clean lines.
                        It looks good.
                        You could make it interesting by mounting non-standard indicators, round or something from another car. Then it would really look custom.
                        You can find some nice LED ones on fleabay
                        私のホバークラフト は鰻が一杯です。
                          Nice job mate & i see what you mean about the air flow being ok as you've taken a picture lower down.
                            Originally posted by blackpoolsparks View Post
                            very clean lines.
                            It looks good.
                            already in the pipeline, watch this space
                              Very very Neat Neil ..... for a first timer
                              Jess
                              "Cos shoert cuts can cost more in the long run"
                              Buncefield Burner
