Re: O/D off light flashing
  • Re: O/D off light flashing
    Right, finally got the surf to a auto specialist, but unfortunately they didn't have a diagnostic reader for it, apparently its hard to find anywhere that has one for an import, but perhaps you know better.
    Anyway, the guy has pressure tested the box and road tested, and he's told me its all as sweet as a nut, he's had it on ramps dropped down the speed sensors and tested them and they are also fine, and eveything is changing as it should be.
    He's told me the box usually goes into fail safe mode (only third gear) if there's a major problem, but its all changing ok.
    He shorted the diagnostic box to give the error code, but there isn't even an error code showing, which he says is weird, but would ensure there is no major problem which coincides with the box pressure being ok.
    He's advised it can only be a very minor fault, such as the relays operating at say 60 degrees, when it should be 50 degrees, but enough to show a fault but not cause any problems.
    He also did a stall test on it, which means nothing to me, but said it was fine.
    He has advised to try and get it on a diagnostic for imports, and the only one he can reccommend at the moment is in the Edgware road
    any advice opinions appreciated,
    thanks
    Fieldsy
