Heated WIndscreen?
  • Heated WIndscreen?
    Like most of my fellow surfers, I am having trouble with my windscreen demister. I have done all the tricks like physically moving the lever arms down below, but I suspect I need to look under the dash.
    What crossed my mind is whether I could fit a heated windscreen, as found on some cars. I have seen this mentioned on L**d R****r Websites, so does anybody know if its possible for our vehicle?
    If you are getting heat out of the heater then you should have no trouble demisting. If not, then suspect blocked heater matrix. Set air to external, not recirculating - full fan full hot and engage aircon to dry the incoming air , open rear window an inch if necesary to improve airflow through vehicle. Should work fine with all if not some of the above.
    I imagine a heated front screen (if available) woudl be horrendously expensive
    Kevin
      Will Try
      Cheers Kev!
