Auxilary belt change
  • Auxilary belt change
    Hi my auxilary belt that drives power steering pump etc needs swopping, is this an easy task? Not much room to move about behind the radiator! Does any of you kind peeps have a "how to" handy for this?
    where abouts are you in Cornwall? if you have any probs and need a garage then there's the one in Camborne i go to
      Its the easist of the belts, if you have a extra battery on that side, take it out and you should be able to reach the bolts OK, 14mm spanner and a prybar to tighen it is all you need. (and small hands)
        Brill, thanks Tony.
          Delabole, near Camelford
            hi m8 as tony said only 10 min job
