gearbox cooler pipe
  • gearbox cooler pipe
    anyone know what size fitting unions are on the gearbox for the transmission oil cooler lines for a A341E transmission
    The A341E is not a Toyota box it was designed and made by Aisin Warner, there are a lot of motor manufacturers out there that fitted this box to their vehicles, and in doing so there were many different applications, do you know where the box originated from?
    www.overfab.uk
      its from a ls400, which has almost the same outer casing as the surf
        Pirtek may be able to assist.
        Eat.Sleep.Surf.Repeat.
          I found out its a m14 x 1.5 thread
