Torque settings
  • Torque settings
    Anyone confirm the torque settings and recommended tighting sequence for head bolts on a 2.4TD (2LT type engine). I have a Haynes Hilux/4-Runner manual that gives Following info:
    1st pass 78nm
    2nd pass turn additional 90 degrees
    3rd pass turn additioanl 90 degrees
    IS THIS OK FOR A SURF???
    Any particular sequence, I'd assume across the corners for 1st/2nd pass and round clockwise for 3rd???
    Any other re-assembly joints that have to be torqued??
    Scuddy
    Look out! Ee
    There's a Doc file with all the info on the homepage. Go here:
    http://www.hiluxsurf.co.uk/
    Look in the information files. Look under Technical, Mechanical.
    Hope this helps,
    Pete
