turbo light
  • turbo light
    1990 2.4 td
    just done egr mod and the turbo light dosnt come on anymore
    took mod off and still no turbo light
    turn ign switch on and turbo light comes on
    drive vehicle and can hear turbo spinning up and no loss of power
    where is turbo light triggered from ?????????????have i disturbed a wire some where
    help
    john
    Try unpluging the ECU for about 20 mins, and reconnect it.
    It should reset itself.
    It's behind the kick panel on the passenger side.
      cheers vince
      in case u are wonderin its not my surf but my brothers
      but he's blaming me
      mine is presently bleeding to death outside
      after last weeks rad strip and clean shes sprung a leak from the drain tap o ring seal, so thats my job for tomorrow morning
        Ever heard of the phrase......'If if aint broke, don't try and fix it'?
        Sorry, could'nt resist.
          Originally posted by john.sally
          1990 2.4 td
          help
          john
          Turbo light is worked by the sensor thats bolted to the side of the air filter box, the hose runs from this, to a clip on the intake elbow, where a little filter is clipped there, then it goes down under the intake elbow and plugs on a fitting in the intake manifold.
            thanks guys i will pass it on to my bro.
            deffinatly i'm normally a beliver in if it aint broke then dont fix it
