Torque Settings??
  • Torque Settings??
    does any one know where to find torque settings for a 2.2l petrol hilux engine from a mk3. cheers
    What settings do you need.
      the torque settings of the head bolts theres 8 bolts, and the cam bolts theres 4 of them. cheers
        What year and engine code is it, also do you mean the camshaftt sprocket or carrier.
          What is it? a 4Y or 20R?
          If its the 4Y, Head bolts are 14mm bolts - pregressively up to 65ft/lb and the 12mm bolts 14ft/lb. Rocker shaft bolts are 17ft/lb.
          If its the 20R Head bolts are 25/40/62 ft/lb. Cam bolts are 15ft/lb.
          Having said that, aways go by the torque settings that come with the head gasket, as they will have developed to match that gasket.
            thank you very much for all your help, thought i was never gonna find out what i needed. thanks alot
