Code 12 Timer control valve
  • Code 12 Timer control valve
    ok im guessing this is the round thing bolted with 2 hex bolts under the 4 fuel out pipes,
    when i was replacing the seals the kit i got from rough trax DIDNT have this (and a couple of other seals) so i got one from a parts shop but it was fractionaly thicker so its possable it is sat a fraction of a mil out from where it normaly goes (could this be it) or is it more likely elecrical, the only aparent problem my car has is the lack of turbo.
    And if this is it can this be sorted without removing the pump (AGAIN)
    Its all fun and games till someone looses an eye!
    To those who have not noticed my reasont problems
    I have just spent 4 weeks fixing a leaky fuel pump,
    i have very little idea what im doing,
    pretty sure the timing belt is ok tho,
    thanx to John "bowella" for that
      Just reading another post code 12 is knackered pump, did you have this code before you took the pump off.
      www.cnpbetterhomes.co.uk
        no i didnt and i know its not damaged,
        i have a fuel filter in the post, so if that dont cure it im gonna have to take the valve off and put a smaller seal in
