O/D light flashing
  • O/D light flashing
    Hi folks.
    The orange overdrive light on my kzn185 tends to flash after I go over 50kph. According to the manual I should instantly get to my local dealer due to a gearbox fault.
    My local Toyota dealer has gone bust, and Toyota Ireland will not even talk to you if you even refer to an import! My mechanic (Landrover & Jaguar) can't find a problem, and I can't find a problem. Overdrive and ECT both work fine, oil levels are fine, and there are no leaks. It runs up and down through the gears without any difficulty.
    I can't find anyone locally whose software can reset the light (I want to see is a an old fault that may have been fixed but light not reset, or a false read).
    Is there any quick reset, or is there a diagnostic tool/package available?
    Thanks.
    David.
    Hello, search on here for diagnostic or diagnostics. It gets covered once a week or so.
      Thanks for that. Unfortunately I can't find the search option!
        Are you taking the pi$$?
        It's near the top of every page!
        But seeing as I'm in a good mood, here is the link to the advanced search page http://www.hiluxsurf.co.uk/forums/search.php
          Moo Chose Grassy Ass.
          I'm technically retarded, so please pardon the many mistakes I will make on here!
          I see the search now (which is the same as on several other forums I use...)
