Largest tire
  • Largest tire
    Hi guys,im just curious as to whats the largest tire i can run with standard suspension,but with a 2" body lift?standard 15" rim.was thinking of 31x10.5 copper discovery stt's but then i saw som Nankang mudstars in 32 x 11.5 for similar price
    [B][FONT="Impact"]Cut my way in...weld my way out![/FONT][/B]
    32"s will fit OK.
      excellent.thank you.will the 31s fit without the bodylift?
        Yes, 31"s were a factory option tyre size.
        Just incase you meant to type 32"s, yes they will also fit with no body/suspension lift.
          Yeah sorry Bushwhacker,thats exactly what i meant!Camskill seems to be the cheapest out there for tires
              sorry to jump in on this thread, but will 285 75 16 be ok on standard 3rd gen alloys?
              thanks
              i x toyoyta surf 1 x toyota supra mk3 turbo auto
                3rd gen alloys are 16" so should be ok.285's i had on my old l200's standard alloys which are the same as 3rd gen surfs alloys
                  cheers
                    Back to this thread again, but has anyone ran a 33x12.5x15 on a standard surf rim?
                      you can yes but they will bulge over the rim of the wheel.Nothing wrong with it but they are better suited for 8jj rims
                      rather than 7jj
                        has anyone ever fitted 33/10.5/15's to a standard gen 2 (stock rims and ride height/body mounting etc)?
                          They wont fit without doing the lifts.You need 4" of lift to fit 33's
                            They'll fit no problem, but you won't be able to go 'round corners.
