A couple of questions
  • A couple of questions
    Hi guys.
    I dunno whther it's a blessing or a curse, the fact I've found your little community. As soon as my dad finds out, I'll be, and hence you'll be, plagued with questions!
    Two questions that he'd like to know the answer to are...
    1) Where is the heater rad (matrix?) located?
    2) Is it a big job/Is there a walkthrough to change the fuel filter?
    I've searched for the answers to the questions, but I haven't been able to find any.
    Thanks in advance.
    The heater matrix is behind the dash, against the bulkhead.
    You have to strip out all of the dash, see this thread..........
    http://www.yotasurf-online.co.uk/pub...ight=hey+jenni
    ...to see what it looks like. Not that hard a job, just lots of bits to take off.
    The fuel filter is normally on tight, its easier to unclip the hoses, and remove the unit complete from the bracket. Then carefully remove the bottem plastic drain tap and sender (you need this bit), then unscrew the filter from the pump. It normally needs a big screwdriver hammered through it to turn it, or use a special filter removing tool while holding the top part in a vice.
      Holy Bejaysus, that was quick!
      Thanks a million for the info. I'll have to hold off a couple of days before telling himself, so it looks like I put in many painstaking hours searching for the answer!! *LOL*
        youth of today....
        it's in me shed, mate.
