Fuel pump wiring.
  • Fuel pump wiring.
    Does anyone here have a wiring diagram for the injection pump or engine ECU on a 2-lte engine. I need to locate the signal wire to the inj.pump from the ECU. There are 2 wires going to a switch/sensor on the pump, one of which is a feed wire and the other a signal wire. Any help would be great. Thanks in advance.
    You can take my 4x4 from me when you prize the keys from my cold, dead hand.
