anti roll bar
  • anti roll bar
    if you have strange noises and handling from your rear check your anti roll bar bushes, this is going to cost me all of £ 7.50 from toyota main agent as you can see i did the same last time i went off road
    Aye, happens (off roadin an such ) quite often. Try doublin the clips (ie buy 4 instead of two and enlongate - slightly ie just enough the outer clips bolt holes. OR make clips yourself if handy with thicker bar from builders yard.....
      Or ....... take the anti roll bar off and save yourself some money
      Roger
        Ding ding! Winner!
          yep just replaced ours and the links for the rear cost us £18 great site for spares www.milneroffroad.com there in matlock we also replaced our o/s cv boot £6.50 and lower o/s ball joint £15 which i found cheap as to the fact that toyota was around £55
          taekwondododo
