2LTE engine fault codes
  • 2LTE engine fault codes
    PLEASE NOTE I CANNOT CONFIRM IF THESE ARE CORRECT
    Re: 2.4LTE Engine just stops for no apparent reason
    engine codes
    1 - Normal
    2 - Turbo boost pressure sensor
    4 - Coolant temperature sensor
    5 - Correction resistance (Pump)
    6 - Pump speed sensor (Pump)
    7 - Throttle position sensor
    8 - Intake air temperature sensor
    9 - Vehicle speed sensor
    10 - Starter switch
    11 - Switch sign (Vehicle not in P or N or A/C on)
    12 - Timer control valve (Pump)
    13 - Crank position sensor
    top man marky. been trying to find these codes for weeks.
    my check light flasing 2,7,8.
    Engine running lumpy. Now i'll have to decide which to change first.
    Any ideas?
    much obliged
    tony
      i'd say that those components where all in the same area.
      i'd remove & refit all plugs around air filter, turbo & throttle body area first to see iff theres any change
        i'd visually inspect the wiring and give it a wiggle first, before you go stripping it down!
          thats what i meant
            disconnected battery to clear all codes and
              disconnected battery to clear codes and see if i got same results.
              just getting 1 flash now which on your list means normal. Now i'm really confused ! Will try unplugging like you suggest.
              For someone not too smart when it comes to cars, this site is a god send.
              CHEERS.
                Looks like i'm not that good on computers either !!
                  one thing i have found with the ecu codes is you have to be careful to watch for high value codes... on my MR2 (Supercharged MK1) i confused code 45 with codes 4 AND 5
                  also if you have a code in there and you reset the ecu faults might not come back for weeks... sometimes they never come back, in which case i'll write it off as a false-positive. Only if a code keeps coming back should something be replaced.
                  [I][B][FONT=Arial][SIZE=2]1993 SSR-X 2.4[/SIZE][/FONT][/B][/I]
                    ECU fault codes can be a bit suspect sometimes.A particular fault code may not mean that part has to be replaced.Sometimes it is something else causing the problem.Once had a car that continually gave a fault code 21 which was the speed sensor.After two new ones were tried there was still the same problem.Never did solve that one even after hours of testing.
                    Neville
