relay rod - pitman arm - idler arm attachents...
  • relay rod - pitman arm - idler arm attachents...
    more steering component advice wanted..
    I have established tie-rod ends need replacing on my 4runner.
    However, it looks like the joints where the 'arms' from the pitman arm and idler arm meet the 'relay rod' are also rocking and loose -
    can these joints be replaced ? and what is the part called?
    surely I don't need a whole idler arm unit and pitman arm unit?
    and who sells these parts
    cheers in advance AGAIN...
    andy
    Landcruiser Colorado
    Sub. Forester
    andy try www.milneroffroad.com look under LN130 steering parts i got my idler arm for £50 as i was told they had been reduced
      some pics
        how much 'play' should there be where the pitman & ilder arms meet the relay rod ? should there be a bit of give, or should all these joints be rock solid ?
        thanks for feedback so far
        Sub. Forester
