fuel pump timing control valve
  • fuel pump timing control valve
    anyone have a wiring diagram for a efi fuel pump timing control valve circuit
    on a 2lte engine. keeps showing a fault changed pump 3 times changed ecd relays and checked fuses in both boxes but have i missed something
    Gerry, I think I;ve got the same problem, does yours go into a limp type mode after 20mins running and brings up a fault 12? I will keep you posted if I have any success in sorting it.
    Cheers Jonswitch
      Surely someone knows what code 12 means in the real world? Theres 3 of us now with a code 12! ???
      ...Woodie http://woodie.pwp.blueyonder.co.uk/D...%20Surfsml.JPG
        i think it means tea break... code 9 is definately a fight and code 10 is stopping boy racers.
          Just a thought but dont you have to unplug the ECU for a minute or so to reset it or have you done that?
          BTW the problem I had where the turbo stopped and the red check light came up has not happened again,,,, yet, (5 journeys to and from work - only about 15 miles each way atm) could it have been dodgy fuel?
          (ed. I removed the fuse to the EFI for 30 secs. and it has cleared the fault code, the car is driving ok again for now but i'd still like to know what causes a code 12)
            Code 22 - patient deceased
            NO WORRIES!
            Rusty
              ONE-DIGIT TWO-DIGIT POSSIBLE CAUSE OF CODE/SYMPTOM
              1 NONE SYSTEM NORMAL
              -- 11 LOSS OF POWER SUPPLY TO ECU
              --IGNITION SWITCH/CIRCUIT
              --MAIN RELAY/CIRCUIT
              --ECU
              6 12 RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
              --DISTRIBUTOR/CIRCUIT
              --STARTERSIGNAL CIRCUIT
              --IGNITER/IGNITER CIRCUIT
              --ECU
              -- 13 SAME AS ABOVE BUT AFTER ENGINE HAS RUN AT 1,000-1,500 RPM
              --DISTRIBUTOR/DISTRIBUTOR CIRCUIT
              --ECU
              3 14 IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
              --IGNITER AND IGNITION COIL/CIRCUIT
              --ECU
              5 21 OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
              OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
              4 22 WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
              --WATER TEMPERATURE SENSOR CIRCUIT
              --ECU
              8 24 INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
              --INTAKE AIR TEMPERATURE CIRCUIT
              --INTAKE AIR TEMPERATURE SENSOR
              --ECU
              -- 25 AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
              --INJECTOR FAULT(S)
              --FUEL PRESSURE
              --OXYGEN SENSOR
              --AIRFLOW METER OR MAP SENSOR
              --IGNITION
              --ECU
              -- 26 AIR/FUEL RATIO RICH INDICATOR
              --SAME AS ABOVE
              --COLD START INJECTOR
              -- 27 SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
              --SUB OXYGEN SENSOR/HEATER/CIRCUIT
              --ECU
              -- 28 No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
              --SAME AS CODE 21
              2 31 MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
              --AIRFLOW METER/CIRCUIT
              --MANIFOLD PRESSURE SENSOR/CIRCUIT
              --ECU
              -- 32 AIRFLOW METER SIGNAL (VANE-TYPE)
              --AIRFLOW METER./CIRCUIT
              --ECU
              14 34 TURBOCHARGER PRESSURE--ABNORMAL TURBOCHARGER PRESSURE
              --TURBO CHARGER
              --AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE SENSOR
              --INTERCOOLER SYSTEM
              --ECU
              -- 35 TURBOCHARGER PRESSURE SENSOR SIGNAL
              --TURBOCHARGER PRESSURE SENSOR
              --ECU
              7 41 THROTTLE POSITION SENSOR SIGNAL--OPEN OR SHORT IN TPS SIGNAL
              --TPS SENSOR
              --TPS SIGNAL/CIRCUIT
              --ECU
              9 42 VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERLA SECONDS
              WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
              --SPEED SENSOR/CIRCUIT
              --ECU
              10 43 STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
              --ECU
              11 51 SWITCH SIGNALS
              IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
              WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
              --A/C SWITCH/CIRCUIT
              --A/C AMPLIFIER
              --TPS/CIRCUIT
              --NEUTRAL START SWITCH/CIRCUIT
              --ECU
              12 52 KNOCK SENSOR SIGNAL--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
              --KNOCK SENSOR/CIRCUIT
              ECU
              13 53 KNOCK CONTROL SIGNAL IN ECU
              --ECU
              -- 71 EGR VALVE MALFUNCTION--EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
              --EGR SYSTEM
              --EGR GAS TEMPERATURE SENSOR/CIRCUIT
              - - 72 AIR CONDITIONER COMPRESSOR RELAY/RELAY SIGNAL
              --A/C COMPRESSOR RELAY/CIRCUIT
              --ECU
