O/d
  • O/d
    can i just ask this,
    i understand that when there is a problem with the over drive the light will flash right.
    so will it flash when when the ignition is on/engine is on
    Not necessarily a fault with the OverDrive, but a fault somewhere in the Electrics or electronics associated with the gearbox and speedo etc.
    Mine flashed with the ignition on and the OverDrive off. My fault was that the speedo wasn't working (which I had noticed!)
      mine will flash but only when im moving ?
        The search feature on here is great for finding solutions to problems like this.
        A search for "reading fault codes" produced 14 results.
        Anyway, been posted a dozen times before, but here's something to get you started:
        All Toyota vehicles with electronic fuel injection utilize the Toyota EFI or TCCS engine management system. This system incorporates many features to enhance performance, emissions, and drivability. One feature is the Self Diagnostic System. The self diagnostic system monitors engine operations and when a particular sensor or input varies out of specified operating parmeters, the "Check Engine" will be illuminated.
        The check engine lamp alerts the driver or technician that a problem exists in the EFI/TCCS ECU or Engine Control Unit or "computer." When the check engine light is illuminated, it is indicating that a problem in the engine management system has been detected. At this time, a "code" may be stored in the ECU which pinpoints a possible component in the EFI/TCCS system. By checking the trouble codes, a possible problem could be narrowed down to a number of causes. While not an exact diagnostic tool, the check engine light and self-diagnostic system can get the individual working on his/her truck close to a possible fault, and, hopefully, to a successful repair.
        Listed below are one and two digit trouble codes for the EFI/TCCS systems and possible causes. As mentioned above, this is not an exact science. Many other component failures can cause similar symptoms that can "mask" the actual cause. EFI/TCCS computer interrogation is one of the last steps to engine diagnostics. A thourough inspection of the simple items should be done prior to any computer-related repairs. Sometimes it's the simple things that will get ya'. In addition, use caution when working on the electrical system of your vehicle. Not only is the electrical system delicate to water, static electricity, and outright physical abuse, the ignition system puts out high voltage as well and you can be serioulsy injured if you do not exercise basic safety.
        READING THE TROUBLE CODES
        Reading the diagnostic trouble codes is very easy. You will need a paper clip to short the check connectors of the diagnostic connector. The diagnostic connector comes in two types. The early system is located on the inner-left fender well and is a round, green connector, usually located near the air cleaner. Simply jump the two terminals in this connector with the ignition switch in the "ON" position and the engine off. Later models, '87 and newer use a multiple terminal "DIAGNOSTIC" connector which is a small, rectangular-shaped grey "box", usually located near the right fender in the enigne compartment. To get codes out of this type of connector, jump the "TE1" and "E1" teminals. Finding these terminals is easy as the inside cover of the diagnostic connector contains a schematic of the connector pinouts. If the underhood emission decal (VECI) is still intact on your vehicle, the proper pins for this are outlined there as well.
        The trouble codes will appear as flashes of the check engine lamp. Be sure the ignition key is on, the engine off, and your foot off of the accelerator when reading the codes. Two different codes may appear: One-digit and two digit. One digit codes have an approximate 4.5 second delay between flashes with the check engine light illuminating for about a half of a second. Mulitiple codes have a 2.5 second delay between them. For example a code two flashes the check engine lamp two times in a little over one second: I I. If two codes are stored, such as a code two and a code four, the lamp may flash as such: ....I I....I I I I. Crude examples but you get the idea. Two digit codes are similar but will flash the lamp with the first number first and the second number last. An example of a code twleve is I ....II and a code twenty four is I I..IIII.
        Later-model EFI/TCCS Diagnositc Connector
        (Photo courtesey of Chris Geiger)
        TROUBLE CODES AND POSSIBLE CAUSES
        ONE-DIGIT TWO-DIGIT POSSIBLE CAUSE OF CODE/SYMPTOM
        1
        NONE
        SYSTEM NORMAL
        11
        LOSS OF POWER SUPPLY TO ECU
        --IGNITION SWITCH/CIRCUIT
        --MAIN RELAY/CIRCUIT
        --ECU
        6
        12
        RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
        --DISTRIBUTOR/CIRCUIT
        --STARTERSIGNAL CIRCUIT
        --IGNITER/IGNITER CIRCUIT
        --ECU
        13
        SAME AS ABOVE BUT AFTER ENGINE HAS RUN AT 1,000-1,500 RPM
        --DISTRIBUTOR/DISTRIBUTOR CIRCUIT
        --ECU
        3
        14
        IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
        --IGNITER AND IGNITION COIL/CIRCUIT
        --ECU
        5
        21
        OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
        OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
        4
        22
        WATER TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
        --WATER TEMPERATURE SENSOR CIRCUIT
        --ECU
        8
        24
        INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
        --INTAKE AIR TEMPERATURE CIRCUIT
        --INTAKE AIR TEMPERATURE SENSOR
        --ECU
        25
        AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
        --INJECTOR FAULT(S)
        --FUEL PRESSURE
        --OXYGEN SENSOR
        --AIRFLOW METER OR MAP SENSOR
        --IGNITION
        --ECU
        26
        AIR/FUEL RATIO RICH INDICATOR
        --SAME AS ABOVE
        --COLD START INJECTOR
        27
        SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
        --SUB OXYGEN SENSOR/HEATER/CIRCUIT
        --ECU
        28
        No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
        --SAME AS CODE 21
        2
        31
        MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
        --AIRFLOW METER/CIRCUIT
        --MANIFOLD PRESSURE SENSOR/CIRCUIT
        --ECU
        32
        AIRFLOW METER SIGNAL (VANE-TYPE)
        --AIRFLOW METER./CIRCUIT
        --ECU
        14
        34
        TURBOCHARGER PRESSURE--ABNORMAL TURBOCHARGER PRESSURE
        --TURBO CHARGER
        --AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE SENSOR
        --INTERCOOLER SYSTEM
        --ECU
        35
        TURBOCHARGER PRESSURE SENSOR SIGNAL
        --TURBOCHARGER PRESSURE SENSOR
        --ECU
        7
        41
        THROTTLE POSITION SENSOR SIGNAL--OPEN OR SHORT IN TPS SIGNAL
        --TPS SENSOR
        --TPS SIGNAL/CIRCUIT
        --ECU
        9
        42
        VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERLA SECONDS
        WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
        --SPEED SENSOR/CIRCUIT
        --ECU
        10
        43
        STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
        --ECU
        11
        51
        SWITCH SIGNALS
        IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
        WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
        --A/C SWITCH/CIRCUIT
        --A/C AMPLIFIER
        --TPS/CIRCUIT
        --NEUTRAL START SWITCH/CIRCUIT
        --ECU
        12
        52
        KNOCK SENSOR SIGNAL--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
        --KNOCK SENSOR/CIRCUIT
        ECU
        13
        53
        KNOCK CONTROL SIGNAL IN ECU
        --ECU
        71
        EGR VALVE MALFUNCTION--EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
        --EGR SYSTEM
        --EGR GAS TEMPERATURE SENSOR/CIRCUIT
        72
        AIR CONDITIONER COMPRESSOR RELAY/RELAY SIGNAL
        --A/C COMPRESSOR RELAY/CIRCUIT
        --ECU
        While a lot of the possible faults in the EFI system point to the ECU iteself, it should be noted that ECU failure is not common. The ECU should be replaced only as a last resort or if all diagnosises points to a bad ECU. Usually, troublesome EFI problems are a result of poor grounds, shorted wiring, and bad connectons at sensors.When all else fails, carefully consult your factory repair manual. It contains more comprehensive diagnostic information and great electrical wiring diagrams.
          Seen this yet?
          http://www.hiluxsurf.co.uk/forums/sh...2&postcount=18
            yea just looked at it there, cheers for that
            now the strange thing is i conected up the E and W ports in the check connector box with an eletric tester pushed th eover drive button in and it just went off as normal did not flash at all !
