Third Brake Light
  • Third Brake Light
    I've just put in a third break light, I couldn't find a 'how to' on here, and I was suprised at how easy it was.
    The interior panel at the back with the interior light pops off.
    Then you find the connector that has two wires running to it, green and white.
    Chop of the connector.
    Connect the green wire to live on your new light, the white to earth and your sorted.
    If you don't fancy drilling a hole in the plastic for the wire you slip it out through a gap in the interior light.
    Then stick the panel back on, and away you go.
    You might want to take out the brake light fuse first, because if those two wires touch you blow the fuse.
    It's in the panel next the gas pedal.
    I suppose the wiring is there so you can connect it to the brake light in the spoiler.
    Theirs also another connector there, looks like it might be speakers or cd multi changer.
