engine swap 3.0td
  • engine swap 3.0td
    Are all 3.0td engines the same?
    Will a 98 unit drop into a 94 surf?
    Mine is the KZN130 the later engines are KZN185
    and is the engine in the automatic different ?
    My engine has a IKZ prefix, I can get a landcruiser engine prefix KZJ
    Does anyone know if the landcruiser engine fits the surf.
    Any assistance is apreciated.
    Regards.
    Regards.
    Elvz would know havent seen her around for a while and theres definitely something missing ... PM her
      she lurks a lot, not much to say lately, most of the questions get answered pretty quick ATM, no point in repeating what some else has said.
      I miss her though This one needs her.
      Paging Elvie!............Elvz to the engine swap dept!.............
        Regards.
        I think the Prado 1KZTE should fit however you may need to move engine mounts as I'm not sure they are in the same place. Basically if the new engine is a 1KZTE (3.0 TD EFI) then you are at least starting with the same basic engine. Unless your original had an intercooler, then that might cause problems as the Prado does I think.
        This is all supposition on my part, Elvie's the one in the know.
