Manual gearbox senders
  • Manual gearbox senders
    While trying to find out why the speedo has stopped working I've discovered 2 senders,each about 1" across, at the top left side of the gearbox have broken wires..are these speedo senders or for the 4wheel drive selector? I can't find anything in the Aussie manual.
    Toyota want HOW MUCH for a sender...
    LN130 2.4 (93) manual
    Thanks in advance
    Bob
    You should have at least a switch for the reversing lights, and a switch for the 4WD light.
    Thanks in advance
    Bob
      Thanks, Tony
        isnt the speedo cable screwed in by hand by the means of a plastic collar about 1" across on the upper right hand side of the transfer case?
        ******edit******
        found a pic of an older gearbox but zooming in I have highlighted where I think you need to check and tighten the cable back in.
          Jim, I think some Surfs had electric pulse speedos fitted . It would have the sensor in the same place though .
            It has a sender for the electric speedo off the left side of the transfer case.
            Reverse light and 4 w/d lights still work, so down to the Toyota dealership to look at the manual on monday.
            The reason the speedo stopped is cause the kph>mph converter has died
            The M8 unit is from www.ncs-systems.com .apparently some of the early units are voltage sensitive and a spike can cause failure, they've now been moded.
            The test is: cut the grey and the purple wire from the M8 and dash plug,connect together on the plug side and if its the unit the speedo should work in kp/h.
