Old 16th August 2005, 08:27   #1
Jezware
Jezware's Avatar
Vehicle: 1992 2.4 SSR-X
Default Fuel Pump Help Needed
After haveing the head fixed this month, the fuel pump has decided to give up. It is p*ssing fuel out when cold, so I am guessing the top gasket has gone, but now the ECU has come up with fault code 12, and the truck is undriveable. So.... Can somebody point out on this picture where the Timer Control Valve is.
I need to get the car home, which is 30 miles away, if I disconnect the Timer control valve, will it drive?
Also, is it possible to change the gaskets without removing the pump, if not, how big a job is it to swap the pump for one from a breaker, (presuming I can get one).
Jez
__________________________________________
Jezware is offline   Reply With Quote
Old 16th August 2005, 12:08   #2
NiftyNev
Senior member
I'm fairly sure the Timer Control Valve is an internal part of the pump and is the gismo that determines which injector gets the fuel and when.Simply put, it means pump out to remove.The fault code may have just appeared because too much fuel is being lost through the leak and this is still ok.The top seals can be done with the pump in vehicle so this may be the best and cheapest thing to do then reset ECU and see what happens.
http://www.toyotasurf.asn.au/techsite/fuelpump.htm
Neville
Old 23rd September 2005, 08:09   #3
phil7230
Default thanks for the info
Hi, i notice a slight fuel leak while changing my oil and filter after much investigatiion i reckon its coming from the top cover of the pump, thanks to your posting its not going to be to difficult to fix, for some time the engine has spluttered for a few seconds when starting from cold, could the leak on the pump be the cause?
Phil
phil7230 is offline   Reply With Quote
Old 23rd September 2005, 17:41   #4
WARRIOR72
WARRIOR72's Avatar
Vehicle: HI LUX SURF SSR LTD 2446 TD 1991
its possible the leak is drawing air back in which makes it hard to start (if at all sometimes!!) get your glow plugs checked and replaced if necc.... winter only just around corner lol good luck!
DONT RUN WIV BIG DOGS IF U CANT PI** UP TALL TREES
WARRIOR72 is offline   Reply With Quote
Old 24th September 2005, 13:21   #5
brian gillies
[QUOTE=Jezware]After haveing the head fixed this month, the fuel pump has decided to give up. It is p*ssing fuel out when cold, so I am guessing the top gasket has gone, but now the ECU has come up with fault code 12, and the truck is undriveable. So.... Can somebody point out on this picture where the Timer Control Valve is.
Cheers[/QUOTE
The timer control valve is under the pump. Follow the grey round plug on the side it is held in with 2 bolts. The number on it starts with 23010.
brian gillies is offline   Reply With Quote
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Leaking fuel pump Scuddy 2.4 & 2.8 6 21st May 2005 06:55
Fuel pump leak... mouldy 2.4 & 2.8 4 5th January 2005 11:56
Fuel pump leak... mouldy 2.4 & 2.8 0 29th December 2004 13:16
fuel leak at fuel pump Help! moshihus 2.4 & 2.8 2 4th April 2004 11:01
Turbo and Pump Advice Needed!! wibblywobbly 2.4 & 2.8 10 19th February 2004 14:42
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
