Vehicle: Gen 2 2LTE Auto
Below are the Toyota part numbers for this repair some parts are optional, used model code LN130-GKMQT should be the same for most;
Gasket
11115-54081-B0 01 08/1989 - 11/1991 2LT#,2L..LN130,8#;MARK B
11115-54081-D0 01 08/1989 - 11/1991 2LT#,2L..LN130,8#;MARK D
11115-54081-F0 01 08/1989 - 11/1991 2LT#,2L..LN130,8#;MARK F
11115-54082-B0 01 11/1991 - 04/1992 2L#..LN130,8#;MARK B
11115-54082-D0 01 11/1991 - 04/1992 2L#..LN130,8#;MARK D
11115-54082-F0 01 11/1991 - 04/1992 2L#..LN130,8#;MARK F
11115-54083-B0 01 04/1992 - 08/1994 2L#..LN130,8#;MARK B
11115-54083-D0 01 04/1992 - 08/1994 2L#..LN130,8#;MARK D
11115-54083-F0 01 04/1992 - 08/1994 2L#..LN130,8#;MARK F
Cylinder Head
11101-54120 01 04/1989 - 06/1992 2LT#..LN130
11101-54121 01 06/1992 - 08/1997 2LTE..LN108,112,130
Water Pump
16100-59155 01 09/1988 - 01/1997 2LT#,2L,3L..LN10#,112,13#,8#
Thermostat
90916-03072 01 08/1991 - 03/1993 2L#,3L..LN10#,13#,8#;*WAX 88-100
90916-03099 01 03/1993 - 05/1995 2L#,3L..LN10#,13#,8#;*WAX 88-100
Timing Belt
13568-54070 01 09/1988 - 05/1992 2LT#,2L,3L..LN10#,13#,8#
13568-59065 01 05/1992 - 12/1995 2L#,3L..LN10#,112,13#,8#
IDLER SUB-ASSY, TIMING BELT
13505-54020 01 09/1988 - 11/1991 2LT#,2L,3L..LN10#,13#,8#
13505-54021 01 11/1991 - 08/1997 2L#,3L..LN10#,112,13#,8#
RING SET, PISTON
13011-54100 01 09/1988 - 08/1997 2LT#,2L..LN108,112,130,80,85;S TD
13013-54100 01 09/1988 - 08/1997 2LT#,2L..LN108,112,130,80,85;O/S 0.50
13014-54100 01 09/1988 - 08/1997 2LT#,2L..LN108,112,130,80,85;O/S 0.75
13015-54100 01 09/1988 - 08/1997 2LT#,2L..LN108,112,130,80,85;O/S 1.00
PISTON SUB-ASSY, W/PIN
13101-54090-01 04 04/1989 - 04/1993 2LT#..LN130;STD,MARK 1
13101-54090-02 04 04/1989 - 04/1993 2LT#..LN130;STD,MARK 2
13101-54090-03 04 04/1989 - 04/1993 2LT#..LN130;STD,MARK 3
13101-54091 04 04/1993 - 08/1993 2LTE..LN130;STD
13101-54091-01 04 04/1993 - 08/1997 2LTE..LN108,112,130;STD,MARK 1
13101-54091-02 04 04/1993 - 08/1997 2LTE..LN108,112,130;STD,MARK 2
13101-54091-03 04 04/1993 - 08/1997 2LTE..LN108,112,130;STD,MARK 3
13103-54090 04 04/1989 - 04/1993 2LT#..LN130;O/S 0.50
13103-54091 04 04/1993 - 08/1997 2LTE..LN108,112,130;O/S 0.50
13104-54090 04 04/1989 - 04/1993 2LT#..LN130;O/S 0.75
13104-54091 04 04/1993 - 08/1997 2LTE..LN108,112,130;O/S 0.75
13105-54090 04 04/1989 - 04/1993 2LT#..LN130;O/S 1.00
13105-54091 04 04/1993 - 08/1997 2LTE..LN108,112,130;O/S 1.00
PLUG ASSY, GLOW
19850-54090 04 09/1988 - 08/1994 2LT#,2L,3L..LN10#,13#,8#;*12V-11V
LN130 2LTE Auto
