Old 20th June 2006, 10:51   #1
M35A2
Senior member
M35A2's Avatar
Default Underseal
Just about to underseal my truck. Got a 5lt can of waxoil for the inside of the chassis and 2 cans of Tetra Shultz for the external bits. Will take some pictures when done.
M35A2 is offline   Reply With Quote
Old 20th June 2006, 11:31   #2
joker??
joker??'s Avatar
good luck !!!!! degreaser is good for cleaning tetra scutz off yourself and spraygun
joker?? is offline   Reply With Quote
Old 20th June 2006, 11:49   #3
Taliesins
Quote:
You will have a lot of waxoil left after doing the inside. You can mix it with the Schutz to make it go further and I think this gives a better result.
Best of luck, and dont forget to wear some form of breathing mask (it gets everywhere).
Taliesins is offline   Reply With Quote
Old 23rd June 2006, 13:13   #4
M35A2
Senior member
M35A2's Avatar
Waxoiled the inside of the chassis, but the outside was a complete botch. The nozzel on the gun was too big and was flooding waxoil EVERYWHERE. I might get it done professionally as lying on your back trying to do the job is a nightmare. At least it's got more protection than what it had before.
Old 23rd June 2006, 20:56   #5
MattF
Banned
MattF's Avatar
What type of spray gun did you use? Finally got round
to doing mine, the other day. Sprayed about two litres
into the chassis rails through about every hole I could see,
and from either end of the rails, then gave a coating over
the underside, and finished off little bits that I missed with
the gun with a brush. Fortunately, I had mine done by someone
else with the combined Waxoyl/Schutz liquid when I first got her,
so the session the other day was an example of rust paranoia.
MattF is offline   Reply With Quote
Old 24th June 2006, 15:23   #6
M35A2
Senior member
M35A2's Avatar
It's a sealey underseal gun suitable for schutz/waxoil (yeah right).
The nozzle was to big and emptied about a litre of waxoil in a matter of 15 seconds. I'm going to pop into Machine Mart and see what their guns are like.
Old 24th June 2006, 15:38   #7
joker??
joker??'s Avatar
m35a2 i used the gun from machine mart the other week
make sure its screwed well tight ,
just been given 2 1/2 litres of waxoyl going to put in a empty schutz tin and spray any other bits i missed,
you get a flexible tube with it to get in the chassis
whatever you do you gonna get covered
persevere mate it will turn out looking good
Old 24th June 2006, 15:40   #8
BUSHWHACKER
Additional Contributor
BUSHWHACKER's Avatar
Top tip.....only wear clothes that you're never gonna wear again!
Old 24th June 2006, 15:54   #9
joker??
joker??'s Avatar
Quote:
wore those throw away overalls lol
Old 24th June 2006, 18:11   #10
POPEYE
I've got a shultz gun that come with a plastic tube to do inside the chassis
but last time i used it (on the serria) the tube shot off and as far as i know is still in the chassis, M35A2 are you sure you got the right nossle on? there should be a small hole one for spraying surfaces and you remove this to screw the flexible one on, Without the small one on you'll shoot the whole lot
rather quickly,
POPEYE is offline   Reply With Quote
