I've NOT got the horn !
  • I've NOT got the horn !
    Horns worked OK yesterday, today no horns?
    I have two loud horns fitted via a relay.
    Fuse in the under bonnet fuse box OK, can hear a relay(?) clicking when the horn button is pressed. In-line fuse from battery to relay OK, earth on relay OK. Wire to horns OK, Sooooooooooo tomorrow I'll check if there is 12v from the horn button wire to relay. Maybe try a direct 12v to the horn button spade on relay.
    In the mean time, anyone with any other ideas??
    Cheers...
    Life on the edge is short, but the view is great !
    VIAGRA is the way to go on this Problem ask VINCE
      playboy ,razzle , escort . or a trip to ann summers
        It could be that the relay contacts have gone kaput. Try the diret juice form the battery. I am wondering why you used a relay?
        Kitesurf (My horn is not very powerful anyway) Phil
        It's only a hobby!
          My 2nd Gen had 2 horns after finding the other wire. Check connections at the horn or like you suggest try it direct from the battery 1st
            Coz they are VERY meaty horns a draw a lot of umph!
              And thats HARD on the battery
              www.daemon4x4.org
                Hello,
                There is a small fuse box by the side of the accelerator pedal - small cover popped off by hand no tools needed - check those fuses are all OK.
                Use the little tool under the engine fuse box cover to pull out the fuses.
                  Originally posted by The Lovely Boyo
                  Hello,
                  I did look at those first, but there was nothing that said 'Horn'. But I can hear a relay near there clicking when I press the horn button.
                  Didn't know there was a fuse removing tool under the main under bonnet fuse box cover.
                    isn't there some fuses or something behind the glovebox
                      Yep, but nothing to do with 'getting the horn!'
                        Not sure, but I have found the 'horn' fuse in the main fuse box in the engine compartment.
                          try a pot noodle there meant to give you the horn.if all else fails i would suggest direct connection to the battery.
                          www.overfab.uk
