Old 20th January 2007, 13:00   #1
T0nk4
Default Overdrive not turning on
hiya peeps,
my brother has a '94 model KZN 130 hilux surf 3l td and has an overdrive problem ( or lack of it)
his overdrive will not turn on, the switch is ok but still no joy.
is there a wiring diagram for the overdrive electrical system or is there anything else he can try??
your assistance will be appreciated.
T0nk4 is offline   Reply With Quote
Old 20th January 2007, 13:20   #2
BUSHWHACKER
Additional Contributor
BUSHWHACKER's Avatar
This any help?
http://www.toyotasurf.asn.au/techsit...odiagnosis.pdf
Old 19th June 2007, 10:57   #3
Artful_dodger
Hi T0nk
I had a problem with the overdrive not kicking in at all,, After spending nearly 800 on a complete gearbox overhaul(inc.solenoids and switches) and a new throttle sensor(119) it eventually turned out to be the main ECU which controls both the engine and the gearbox.
In the end i had to buy another surf because Toyota no longer manufacture that particular ECU. I'm still hopeful that a wrecked surf will come along so i can use it for spares.
Paul
Artful_dodger is offline   Reply With Quote
