ok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...
spotlight wiring
Originally posted by rally_manok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...
Simple spotlight wiring diagram.........Last edited by BUSHWHACKER; 19 January 2012, 01:37.
if wiring in front grill switch should be on lower front off side of dash or on centre console ( up date profile to give us a clue )Originally posted by rally_manok surf's own spotlight wiring.my surf has a bull bar and i just fitted spotlights to it using exsiting brakets conected the exsiting wiring up (surf's own wiring) nothing!!! is there a switch or where is the fuse/relay any help please...Surf.gone but not forgotten
disco now gone aswell
my 2 gen had and my 3 gen has but both are pain as they can be switched on with just the side lights
got a new set of spots so will be fitting them tomoz hopefully and this time i will wire them via a relay and use the hi beam as a trigger wire and go via the dash switch so can isolateSurf.gone but not forgotten
sorry peeps but suffering from man's flu.Lreg 3.0td SS-g
.so i am
looking for a switch in centre console but you say there is no fuse or relay in this circuit, is that why they have yellow fog lamps as standard .so when i
test i presume that this circuit will become live on dip beam as you can use fog lamps this way .mmmmmm will try tomorrow .been thrown out the pit by the wife coughing to much
the standard wiring is via a relay but the spots can be left on as they are linked to the side lights not the hi/lo head lights.Originally posted by rally_mansorry peeps but suffering from man's flu.Lreg 3.0td SS-g
.so i am
Originally posted by rally_manOK put sidelights on in fact put all lights on switched on but sill no power to spot/fog wiring can anyone tell me where fuse/relay is. (mud skipper)
The fuse/relay for the front foglights will be where ever the previous owner fitted it. As I said on the first page, spot/foglights were not fitted as standard to any 2nd gen Surf!
