Old 28th January 2008, 18:56   #1
maxwell-1
Default ecu auto-manual
hi can anyone tell me if a 3.0 auto ecu is the same as a 3.0 manual one,also the 2.4 one ?will it fit a 3.0???
cheers
maxwell-1 is offline   Reply With Quote
Old 29th January 2008, 12:58   #2
davemaxx
davemaxx's Avatar
there is a link somewhere indicating that the ecu operates the auto transmission, but if fitted to a manual the engin will run but throughs a fault light on in the dash.
read - (2.4 ECU - Auto & Manual) - by saatman at the bottom of this page.
davemaxx is offline   Reply With Quote
Old 2nd February 2008, 02:35   #3
squipper
intermediate surfer
The 2.4 ECU isn't compatable with the 3 Ltr & the manual also. I've just had my Surf off the road for 5 whole months with an ECU problem as no garage could identify the exact fault! I'm suspecting that you have the KZN130 model? If you have an ECU problem, you'll be searching for donkeys, probably to no avail. Toyota Japan have even stopped making them (were around the 600 mark anyway!).
This guy in Plymouth is fantastic, he fixed mine for 160 ish & it sorted out a few other niggly problems, like Overdrive not working etc.
http://www.the-ecu-doctor.co.uk/
Hope this helps
squipper is offline   Reply With Quote
Old 2nd February 2008, 12:44   #4
davemaxx
davemaxx's Avatar
i'll make a note of that contact detail,
i almost feel like getting mine fixed beffor it breaks, just in case at that price!
Old 4th February 2008, 14:42   #5
maxwell-1
i was looking at a four runner one but sure if it's the same as the surf one?both are from a manual version 3.0lt
Old 5th February 2008, 20:53   #6
maxwell-1
anyone know???
Old 5th February 2008, 21:40   #7
squipper
intermediate surfer
Don't think they will be compatible?? For Surfs, I am led to believe that the fuel injection pump is controlled by the ECU to alter injection timing. As apposed to 4 runners which utilise mechanically controlled fuel injection.
Maybe TonyN, Koi or Bushwhacker will confirm for sure?
Old 7th February 2008, 09:36   #8
maxwell-1
cheers for that,i thought that was the case just wanted someone else to confirm,regards dan
