Go Back   Hilux Surf Forum > HILUX SURF FORUMS - TECHNICAL > Technical - Mechanical - General
Thread Tools Display Modes
Old 7th October 2009, 17:59   #1
petepony
Default 3.0ltr KZN185 Tork/Torque settings on head bolts
Hi
Just bought a new head from ebay 400 to the door and I'm in the middle of fitting it but I cant find my Surf bible its all straight forward so far but I need to know how tight I should tighten the head bolts.
I did think of using the colour tork settings technique but since I've paid out so much I best do it properly,
So do any of you know the correct torque/tork settings for head bolts on a KZ1-TE 3.0Ltr engine in my 3rd Gen surf,
Thanx
Pony
petepony is offline   Reply With Quote
Old 7th October 2009, 20:17   #2
GRASSMAN
Quote:
Originally Posted by petepony View Post
Hi
Thanx
Pony
They don't use torque as a final setting they are angular
on the 2.4, it's a torque nip of 56 mn? then two pulls @ 90 degrees,
I used tippex, on bolt head and cylinder head, but i'm not sure on
the 3.0l sorry.
Gman.
If it aint broke, keep goin' till it is.
GRASSMAN is offline   Reply With Quote
Old 7th October 2009, 20:21   #3
Shalershasker
Contributor
Shalershasker's Avatar
If i've read it right, Cylinder head bolts = 400kg-cm, 29ft-lb, 39Nm.
It then says to tighten a further 90 degree's on each bolt in sequence and then a further 90 degree's again, each bolt in sequence.
Shalershasker is offline   Reply With Quote
Old 7th October 2009, 20:24   #4
Ava_Banana
Ava_Banana's Avatar
This previous post might help:
http://www.hiluxsurf.co.uk/forums/sh...ad+bolt+torque
Ava_Banana is offline   Reply With Quote
Old 7th October 2009, 20:29   #5
stormforce
stormforce's Avatar
Pete i am down loading a document and going to send to you in a mo witha ll you need
stormforce is offline   Reply With Quote
Old 7th October 2009, 20:33   #6
GRASSMAN
That's the one!!
Gman.
Old 7th October 2009, 21:19   #7
petepony
Hi guys
A big thanx to you all, Im off now to the garage armed with your info and a can of beer or 2
Thanx again
Pony
Old 19th December 2009, 16:08   #8
roundabout
Thumbs up tourqe settings
is it not on the back end of rocker cover like the2.4.just got my beast back from the head doctor.:
roundabout is offline   Reply With Quote
Old 19th December 2009, 17:05   #9
fatfires
Additional Contributor
fatfires's Avatar
Hi
Thanx
Pony
If you got your head off ebay not too tight!
Tony
fatfires is offline   Reply With Quote
Old 19th December 2009, 17:31   #10
stormforce
stormforce's Avatar
Pete has had his head done back in October when he last posted
