Go Back   Hilux Surf Forum > HILUX SURF FORUMS - GENERAL INTEREST/CHITCHAT > General
Thread Tools Display Modes
Old 25th August 2010, 00:32   #1
wishbone
wishbone's Avatar
Default 6 point ring spanners - who makes 'em ?
Having had a few 10mm and 12mm bolts round off using normal ring spanners (in places that a wall drive socket won't fit) I've been looking for ring spanners with 6 point wall drive fittings instead of the standard 12 point ones.
Can't find any.
Anyone know who makes these ?
Cheers,
Rob.
wishbone is offline   Reply With Quote
Old 25th August 2010, 00:43   #2
BUSHWHACKER
Additional Contributor
BUSHWHACKER's Avatar
http://www.halfords.com/webapp/wcs/s...egoryId_165572
Old 25th August 2010, 00:50   #3
Albannach
Snap-On do flank drive spanners too.
Albannach is offline   Reply With Quote
Old 25th August 2010, 00:55   #4
wishbone
wishbone's Avatar
Surely they're 12 point like the ones in my Halfords pro kit sitting in my car ?
I'm looking for a ring spanner like these snap on's but at affordable money...
File Type: jpg UsedSnapOn1HalfTo3EighthsCombinatio.jpg (20.5 KB, 37 views)
Old 25th August 2010, 00:57   #5
wishbone
wishbone's Avatar
Quote:
Cheers Andy - You posted that while I was searching for the pic.
Old 25th August 2010, 01:00   #6
BUSHWHACKER
Features and benefits
  • Open ends are angled at 15 to allow greater access in confined spaces
  • Ring ends drive on fastener flats, not corners, to prevent rounding
  • Sizes: 8, 9, 10, 11, 12, 13, 14, 15, 17, 19mm
Old 25th August 2010, 01:03   #7
Albannach
The Halfords ones and the Snap-On flank drive ones don't use the points of the nut hex for drive, they drive from about 1/3 of the way down the edge (flank/flat) of the hex, so shouldn't round the nut.
The Snap-On ones work well and I've used them to remove worn nuts in the past. I can't comment on the Halfords ones as I've not used them on damaged nuts (yet!).
Old 25th August 2010, 01:05   #8
wishbone
wishbone's Avatar
I've been caught out recently by ordering 3 spanners from silverline advertised as 'wall drive' and when they arrived they were exactly the same as normal 12 point ring spanners. I'm guessing Halfords Pro use the same line of advertising..
"Ring ends drive on fastener flats, not corners, to prevent rounding"
Old 25th August 2010, 01:07   #9
wishbone
wishbone's Avatar
I own the halfords ones already (unless they look like the 6 point ones in the pic I posted) and they are no good for badly corroded nuts.
Old 25th August 2010, 01:08   #10
Albannach
They do look the same, but they are different. On the spanner, the points aren't as sharp and the bit between them is much larger and more curved.
