Old 16th September 2010, 09:45   #1
funkykebab
Default Shift Lock controller...
Hi
My shift lock controller was burnt out when I brought my Surf....So I thought easy fix....got one from fleabay and plugged it in....but still no joy.
The old was badly burnt out so I was think could this have done more damage? blown a relay or fuse for example....if so what one?
By the way I swapped it all out including the white plastic bit.
Matt
funkykebab is offline   Reply With Quote
Old 16th September 2010, 09:47   #2
stormforce
stormforce's Avatar
there is a 4wd ecu/relay behind the panel below the stereo.It might pay to try replacing that to see if the 4wd works
stormforce is offline   Reply With Quote
Old 16th September 2010, 10:37   #3
funkykebab
4 wheel drive engages and works fine....I can release with the red button but not from the foot brake!
very weird!
Matt
Old 16th September 2010, 10:50   #4
stormforce
stormforce's Avatar
up under the brake pedal is the switch for the brake lights.I am wondering if that switch also does the electrics for the selector lever aswell.
Sorry i was getting mixed up on the levers in the other post
Old 16th September 2010, 10:54   #5
Chillitt
Chillitt's Avatar
Do your brake lights work?
it's in me shed, mate.
Chillitt is offline   Reply With Quote
Old 16th September 2010, 10:57   #6
funkykebab
as far as I know the brake lights work...will check when I go back to collect it this afternoon.....
Don't have make a diferencr getting out of the hilux into my little corsa van for work!
Matt
Old 16th September 2010, 11:04   #7
stormforce
stormforce's Avatar
As Chillit says if a brake light is out then you wont be able to move the selector unless you press the red button
Old 16th September 2010, 18:57   #8
Leodis
Not true I drove mine with both brake lights out (luckily the wife noticed before the police) but I had no problem selecting gears.
Leodis is offline   Reply With Quote
Old 16th September 2010, 19:13   #9
funkykebab
Well.....it was my bulbs.
Both had blown, both now changed and everything working nicely!
Matt
Old 16th September 2010, 19:30   #10
blackpoolsparks
Quote:
私のホバークラフト は鰻が一杯です。
blackpoolsparks is offline   Reply With Quote
