Vacuum pipes come off - where does it come from??
  • Vacuum pipes come off - where does it come from??
    Hi guys,
    Need a bit of help – bunged a new starter on the LN130 today – in the process I managed to push off one of the vacuum pipes – resulting in a check engine light.
    I know which pipe it is – But I can’t seem to find the actual pipe in the engine bay!
    It’s come off the solenoid that sits on top of the inlet pipe from the turbo, it has two connectors on the front and one (that’s missing) on the back – the electrical connector is blue colour. It's the solenoid thats close to the fuel filter.
    Can anybody explain to me where the pipe that missing comes from and I’ll trace it back.
    Many thanks,
    Dom
    Any help?
      Many thanks, but I think thats the diagram for a 2LT, thye LN130 is a 2LTE.
      Looks like the end that is missing just vents to the air with a small black filter on it.
      So I must have knocked something else knocked something else off!
      Dom
        Well (pushes glasses up nose and adopts superior look), the LN130 can be either a 2LT or a 2LTE, depending on the age.
        Vacuum layout is, I think, the same anyway.
          2L-TE
            I stand corrected. That's quite different
              Aye, a big red cross is way different to what you posted. Ya dumplin'...
                I copied the URL and pasted it into me browser.
                  Way too complicated for me.
                    Ok, reset the ECU, still runs rough and has a check engine light still.
                    ECU returns error code 4 – coolant temp sensor and that’s located right by the starter!
                    So (when it warms up a bit!) I’ll take another look.
                    Thanks all.
                    Dom
                      Ok, I’ve managed to break the sensor – anybody know where I can get another one from cheap?
                      Dom
                        ask richard (stormforce) or maybe albannach, lord lucan or stick a wanted add up mate
                        i was under the impression that the temp sender was on the thermostat housing (it is on mine) does it have two then?
                          well i've had a search and there are two one is just above the starter from what i've just read its fitted to a lot of other toyotas so intermotor do a pattern part have a search using "ln130 temp sensor" it will show what i have just seen
                            It has two of them, the one on the top of theengine is just for the dash - the one just above the starter sends signals to the ECU.
                            Cheers,
                            Dom
                              Cheers,
                              Dom
                              yep did remember i was being blonde mate like i posted have a search through the posts for temp sender and it will come up i'm sure it was tonyn who found the cross reference to other toyotas
