I did this today, just to be safe in the knowledge it would work properly.
2nd gen 3.0
Easy job. Remove shroud to get plenty of room to work.
[IMG]
[/IMG]
Undo the 4 bolts holding fan assembly on
[IMG]
[/IMG]
remove fan from viscous coupling, 4 nuts.
[IMG]
[/IMG]
Use an impact driver to undo the screws holding both halves of assembly.
[IMG]
[/IMG]
turn both parts over and let the old oil drain out, give it all a good wipe down and then replace the oil. Assemble parts and bobs your uncle.
don't disturb the rubber seal when taking apart and cleaning.
[IMG]
[/IMG]
					2nd gen 3.0
[IMG]
[/IMG]Undo the 4 bolts holding fan assembly on
[IMG]
[/IMG]remove fan from viscous coupling, 4 nuts.
[IMG]
[/IMG]Use an impact driver to undo the screws holding both halves of assembly.
[IMG]
[/IMG]turn both parts over and let the old oil drain out, give it all a good wipe down and then replace the oil. Assemble parts and bobs your uncle.
[IMG]
[/IMG]
