Found a way of fitting the ECU behind the kick panel........
Get rid of the plastic brackets that secure the two Surf multiplugs and tuck the wiring up out of the way. Then bash flat two small areas where the side metalwork meets the floor. You'll see where when you offer up the ECU into position.
It's a very tight fit, but a better solution I think. I've got some stick-on foam strip that'll cushion the ECU against the bare metal to prevent any vibration.
Now there's no need to destroy the glovebox to hide the ECU.
