@ vince or anyone who can advise
  • @ vince or anyone who can advise
    I need to connect my cyclone alarm to the central locking of the surf. But need to know if its positive trigger , negative trigger, or positive/negative trigger.
    And which 2 wires would be for the central locking coming from front door.
    You connect into the C/L control box above the fuse box behind the kick panel. White and white/blue stripe if I remember correctly.
    Surfs are negative trigger.
    Remote start needs to be spliced into the ignition before the immobiliser, i.e between the ignition barrel and multiplug, and it also needs a signal from the tacho, orange wire from the alarm unit to the black wire with silver dots in the 12 pin ECU plug.
    Crank signal wire is the thin black wire with silver dots at the ignition multiplug.
      Dude your a star .
      Cheers muchly.
        Is this the kick panel in drivers footwell or passenger footwell
          Central locking module is behind the driver's kick panel above the fuses, a black box about the size of a cigarette packet.
          ECU is behind the passenger kick panel.
            Arrrrggghhh help lol
            I've found the door control box mate but there's no white and white/blue stripe wires.
            There is a blue wire, a blue with white stripe wire, a blue with red stripe wire, a small white with black stripe, a white with red stripe, and can't remember the others. So now I'm stuck
              Hang on, I'll go outside and look in Lexurf's.........
              Stay tuned.
                Cheers dude if you could. And tell me which wire has to go to which .
                  Sorry mate, my bad, I must have been thinking of something else.
                  Red wire with white stripe and silver dots.
                  Red wire with yellow stripe.
                  One is lock the other unlock, but can't remember which is which, it won't harm anything if you wire them back to front when testing the remote though.
                    Lmao
                    Cheers, ill give it another go and see what happens lol
                      It works.
                      I now have working remote central locking from the alarm fob. All that's left to do in the week is sort the remote start .
                      Thanks for the help I appreciate it.
                      And yes i did get the wires the wrong way round just lol so it unlocked when I armed it and vice versa .
                        Marvelous!
                        Does your kit include the three pre-wired relays for the remote start?
                          Yes it does ,
                          I've got to fit the same alarm to the scooby next week too lol, bought 2 at the same time.
                          I love the 6 tone siren on it .
                            I don't suppose you know which wires on the ignition multi plug are which wire do you.
                            I'm struggling with the remote start as I can't find my multi meter anywhere
                            Cheers .
                              Black/red stripe = Ignition 12v
                              Blue/red stripe = Acc.
                              Thin black/silver dots = Crank signal.
