Fixing Error 5 - Correction resistance (Pump)
  • Fixing Error 5 - Correction resistance (Pump)
    Error code 5 relates to a pair of resistors on the side of the injection pump.
    The resistors are installed when the pump is calibrated and fine tune the timing and fuelling.
    I measured both resistors. The grey one was 0.622kΩ while the beige one was open circuit. The insides are potted in epoxy, so I dug out the trusty Dremel and went in.
    The original epoxy.
    After a bit of Dremel action.
    You can see a pair of solder tabs sticking up - the original resistor, which I ground away, was soldered on here. Judging from the resistor body, it was no more than a standard 0.25W resistor.
    The problem now was knowing what value the resistor was originally.
    I managed to find a scan of the manual for the Denso injector pump here. I've also converted it into a pdf that you can grab from here.
    From that, I was able to work out the resistance value from the part numbers. Here's a list linking to the resistors which are available from Farnell. First, the grey one.
    001 - 0.243kΩ
    002 - 0.267kΩ
    003 - 0.294kΩ
    004 - 0.316kΩ
    005 - 0.348kΩ
    006 - 0.384kΩ
    007 - 0.412kΩ
    008 - 0.453kΩ
    009 - 0.487kΩ
    010 - 0.523kΩ
    011 - 0.576kΩ
    012 - 0.619kΩ
    013 - 0.681kΩ
    014 - 0.732kΩ
    015 - 0.787kΩ
    016 - 0.866kΩ
    017 - 0.931kΩ
    018 - 1.020kΩ
    019 - 1.100kΩ
    020 - 1.210kΩ
    021 - 1.330kΩ
    022 - 1.430kΩ
    023 - 0.068kΩ
    025 - 0.100kΩ
    026 - 0.121kΩ
    027 - 0.133kΩ
    028 - 0.154kΩ
    029 - 0.174kΩ
    030 - 0.196kΩ
    031 - 0.221kΩ
    Now the beige one.
    001 - 0.154kΩ
    002 - 0.174kΩ
    003 - 0.196kΩ
    004 - 0.221kΩ
    005 - 0.243kΩ
    006 - 0.267kΩ
    007 - 0.294kΩ
    008 - 0.316kΩ
    009 - 0.348kΩ
    010 - 0.383kΩ
    011 - 0.412kΩ
    012 - 0.453kΩ
    013 - 0.487kΩ
    014 - 0.523kΩ
    015 - 0.576kΩ
    016 - 0.619kΩ
    017 - 0.681kΩ
    018 - 0.732kΩ
    019 - 0.782kΩ
    020 - 0.866kΩ
    021 - 0.931kΩ
    022 - 1.020kΩ
    023 - 1.100kΩ
    024 - 1.210kΩ
    025 - 1.330kΩ
    026 - 1.430kΩ
    027 - 1.580kΩ
    028 - 1.780kΩ
    029 - 1.960kΩ
    030 - 2.210kΩ
    031 - 2.490kΩ
    Solder the appropriate resistors in.
    Now they need sealing from the elements. Check they read ok on a multimeter first though! After a good clean in some alcohol, I used some Sugru to seal them up.
    You could use some proper potting compound or even some mastic, but ONLY neutral cure mastic. If the mastic smells of vinegar, don't use it! The acetic acid released as it cures will eat into the resistor wires.
    After all that, I reset the ECU and the code 5 had been eliminated :-)
    https://galooph.com
    Nice work. Good find on the pump manual
    (I just took a pair off a spare pump for a recent job... )
      Nice job, galooph. Thanks for all the detail.
        Wow, that's pretty cool!
        '96 Toyota Hilux Surf SSR-G - RIP
          Mate - great post - on the Aus site it has set off a line of enquiry about increasing the resistance of the grey (timing) corrector so that the timing is advanced, giving better performance and fuel economy. We are testing now - we are using a variable resistor to find the optimum setting.
          One question please: In your table of resistances for the grey resistor, I see that resistance increases from 0.243 on part 001 up to 1.430 on part 022 (which is the highest) and then drops back to 0.068 on part 023 (which is the lowest). Then Parts 025 to 031 work their way up to 0.221
          Any chance please that you could show us the formula you used to calculate these? We need to be sure that Part 22 - 1.430 k ohms is the highest resistance. Would have thought it would be Part 31
          Thanks a million. Our thread is at http://www.toyotasurf.asn.au/forum/v...=227702#227702
            The part numbering is out of sequence. I grabbed those resistor values from this page of the Denso pump manual. No idea how the values are calculated.
            Cool - I'll have a read!
            Dan
            https://galooph.com
              i know, old tread, but,
              what would you put on a 2nd gen 1kz intercooled, egr gone, manual?
              thanks
                Lead to believe 1.5kohms in each.
                I am running 1.5k in the grey one which is timing
                  thanks,
                  i was thinking to swap the 2 of the prado i took the intercooler off, but i wasn't sure if doing this it will work better than swapping them for the prado ones
