Old 9th October 2003, 11:35   #1
bazz
bazz's Avatar
Vehicle: Hilux surf, 2.4td, 1990
Unhappy engine fault codes
does anyone know how to get the engine management fault codes on a 1990 ln130 2lt, i've been told that if you have bridge two wires in the diagnostic port under the bonnet by the battery (little grey box) then numbers or lights will come up on the dash giving you a fault code, but i cant seem to find out which wires. any help would be great as im having a stressfull time figuring out why it keeps cutting out!!
cheers
baz
bazz is offline   Reply With Quote
Old 9th October 2003, 12:34   #2
NiftyNev
Senior member
Quote:
cheers
baz
Just copied this from our Aussie site.
"Under the bonnet on the drivers side, next to the fuse box is a small black box with a flip top lid. This is for diagnostics.
With the ignition off, transmission in P or N, a/c off and throttle fully released, connect the terminals E1 and TE1 with a small piece of wire or a paper clip.
Turn the ignition to on and codes should be displayed on the instrument cluster with the little check engine light.
To clear any codes either disconnect the battery or remove the ECD relay for one minute."
Here is the 2LTE fault codes:
1 - Normal
2 - Turbo boost pressure sensor
4 - Coolant temperature sensor
5 - Correction resistance (Pump)
6 - Pump speed sensor (Pump)
7 - Throttle position sensor
8 - Intake air temperature sensor
9 - Vehicle speed sensor
10 - Starter switch
11 - Switch sign (Vehicle not in P or N or A/C on)
12 - Timer control valve (Pump)
13 - Crank position sensor
Neville
Old 9th October 2003, 13:04   #3
bazz
bazz's Avatar
Thumbs up
cheeers for the info neville,
baz
Old 9th October 2003, 22:54   #4
TonyN
Super Moderator
TonyN's Avatar
Vehicle: 96' 3.0TD Intercooled Surf, 84' 2.0 4Runner, 02' Subaru Legacy Outback...
Would a 1990 be EFI? Thought only the EFI motors had diagnostics?
Old 10th October 2003, 00:08   #5
gemini
gemini's Avatar
Quote:
not according to toyota, mid 91 they supposed to have changed to efi, but there is some members that have efi in 90 surfs which they said was original, so ???????????
[size=5][/size]
gemini is offline   Reply With Quote
Old 10th October 2003, 05:35   #6
bazz
bazz's Avatar
well i have this diagnostic box under the bonnet and its a 1990 model
Old 10th October 2003, 17:48   #7
TonyN
Super Moderator
TonyN's Avatar
Do you have an engine check light in the dash? thats what you need to count the flashes after shorting the terminals in the diag. socket.
Old 10th October 2003, 18:18   #8
Koi
Rast ich, so rost ich
Koi's Avatar
Vehicle: Subaru 2.5 turbo intercooler
Should be the red light on the opposite the green turbo light, mines a 1990 and thats where it is
Koi is offline   Reply With Quote
Old 10th October 2003, 21:49   #9
TonyN
Super Moderator
TonyN's Avatar
Quote:
You know, it was nagging at the back of my head that I'd seen the diag. socket on a non-EFI truck, now I remember, it was on yours.
So the little red light in the rev counter works the same as the later engine shaped dash light on the later ones?
Old 12th October 2003, 20:56   #10
icsys
icsys's Avatar
Vehicle: Metallic grey 1992 Surf 2.4 TD ssrx Auto (2LTE)
OK, on the subject of check lights.
As I don't have a user manual, does this check light come on under normal driving when a fault develops?
Or does it only come on when the terminals are shorted as above?
If there are no faults am I right to assume that it will come on and not flash?
Hope you all enjoyed your day at the pit (those that went) whilst I was grafting at work.
Ian
One day my paranoia will go away!
icsys is offline   Reply With Quote
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
Similar Threads
Thread Thread Starter Forum Replies Last Post
A quick engine oil question... icsys General 1 14th October 2003 15:00
weekend humour Draig General 8 10th October 2003 18:00
New engine for '87 HIGH-LUX Technical - Mechanical - General 0 19th September 2003 21:30
engine swap 3.0td patzx12 3.0 Turbo Diesel 3 17th September 2003 08:31
Replacement engine Surferh20 Wanted - Parts 4 1st September 2003 22:17
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
