1st September 2004, 15:47
#1
Not so newbie
Vehicle: '92 Surf - BIG Black Mother
starting - glow plugs
I have recently read a lot of 'bad starting' threads re 2.4 surfs. Some of which mine suffered from.
On buying mine i was told to wait until the glow plug lamp goes out before starting the engine - particularly when cold.
Which i did and found mine to be a bit lumpy and smokey first thing and I needed idle up on and had to be a bit hard on the gas.
Next visit to grease monkey and he tells me i should also wait for a further 'clunk' before starting.
Surf starts a little better but still need idle up and bit of gas - just a little bit lumpy still.
So on assuming its the glow plugs going i take it to grease monkey and he now informs me that there is another 'click' after the clunk - you still with me so far.
Apparently its "half current at the clunk and no current at the click on the cold starting circuit".
Anyway prior to going to the expense of having the glow plugs replaced - he now says i must wait for the click after the clunk when cold starting particularly first thing in the morning when its cold.
So its about 20secs at least before the circuit is closed.
Didint somebody once say clunk click every trip - well they must of had a surf.
I hope this is of some help to those people still experiencing starting problems - this may or may not help - but this is how we are supposed to start them, when cold to avoid damage to the plugs and starting circuit, otherwise you will need new plugs quicker than normal.
NO MORE TRUCK
1st September 2004, 17:24
#2
JD Powered
Vehicle: 1994 KZN130 Metallic Blue 3.0 SSRX
The glow plugs have two stages to them that Toyota call "Lighting Time" and "After Glow time". Both are controlled by a Water Temperature sensor via the ECU (On ECU controlled engines e.g. 2LTE not 2LT) The lighting time is upto 5 seconds.
The after glow is for for cold running to give you better economy after the starting (I guess this is the half and full current that your monkey is talking about but I haven't heard that one before). This will run for upto 120 seconds but is not part of the starting cycle.
If it is still lumpy after the five seconds then you are likely to have a problem with one or more of the glow plugs.
If it starts OK after a prolonged time then they are likely to be working but on their way out. If it still runs rough then something aint right.
Rich.
1st September 2004, 17:43
#3
Vehicle: GREEN is the Best'est
The other day a similar question came up on http://www.yotasurf-online.co.uk/public/forums/showthread.php?t=7826 & Koi suggested a way to test the Glow Plugs.
Hope it helps
[FONT=Franklin Gothic Medium][COLOR=Magenta][SIZE=2][B]SEWERAT BOB[/B][/SIZE][/COLOR][/FONT]
[SIZE=3][COLOR=SeaGreen][I][COLOR=Lime][B]I just sit here & looks out to sea or if i'm really rushed then i just sits here & continues to look out to sea[/B][/COLOR][/I][/COLOR][/SIZE]
1st September 2004, 19:32
#4
Rast ich, so rost ich
Vehicle: Subaru 2.5 turbo intercooler
Rich.
Agreed if you need to wait this long then I would suggest something is wrong, plugs not working properly etc.
Both my 2.4 & 3.0, turn on ignition wait for light to go out and they fire up straight away. Replaced the plugs on my 2.4 last year and wow what a difference it was with new plugs.
2nd September 2004, 08:41
#5
Senior member
thumper
I have done some tests on the starting circut in my 2.4 and what your grease monkey says seems to be pretty accurate.Mine works fine and I was doing this to determine how the system works to help someone else with a problem with theirs.I usually start after the clunk and works fine for me.New plugs may be what you need.
Neville
2nd September 2004, 09:13
#6
Not so newbie
plugs
i guess for the cost it makes good sense - especially if you notice a difference - ok new plugs it is - still its pretty good when your spanner tealks himself out of work at least hes not ripping me off.
for the record hes dave matthews of north view garage - bristol
he 'specialises' in jap imports, and he is very very reasonable - for all those people who need a spanner in or around bristle.
cheers for you help
NO MORE TRUCK
2nd September 2004, 12:48
#7
Vehicle: hilux surf,2.4td,1993
cheers for you help
I Have Just Purchased A Surf And Light Does Not Go Out.I Wait Till Buzzer Sounds That Tells Me Everything Is Ok And Turn Over Engine.It Always Starts First Time And Glow Plug Light Goes OutAs Soon As I Have Turned Over Engine. I Have Been Told This Is Ok But I Am Not Sure,What Do You Think
2nd September 2004, 14:51
#8
Vehicle: 1994 SSR-X 3.0TD Auto Dark Blue over Silver
The light does not come on on mine - is this most likely a glow plug fault or is the lamp broken? Never had any problems starting.
[SIZE=7][COLOR=YellowGreen][SIZE=5][FONT=Comic Sans MS]The difference between the men and the boys .................... the price of their toys ![/FONT][/SIZE][/COLOR][/SIZE]
2nd September 2004, 16:32
#9
JD Powered
More likely to be the lamp if it starts OK.
R.
Quote:
2nd September 2004, 16:59
#10
I thought / hoping this was the case - on that basis how many idiot lights (and what) are ment to appear when the ignition is switch on?
TA
Ali
| Thread Tools |
| Display Modes |
Linear Mode
You may post new threads
You may post replies
You may post attachments
You may edit your posts
vB code is On
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Glow Plugs
Ems and Jim |
Technical - Electrical |
4 |
12th February 2004 00:03 |
Glow plugs
robnw67 |
2.4 & 2.8 |
2 |
18th November 2003 17:41 |
Glow plugs
Delboy |
2 |
4th November 2003 14:33 |
Glow Plugs
Pete |
Technical - Mechanical - General |
1 |
25th September 2003 16:36 |
Glow Plugs
JimL |
15 |
11th September 2003 23:24 |
All information and images on this website
remain the property of the owner and no use shall be made of them elsewhere
in whatever format without the express permission of the owner. All
Corporate trademarks are the property of their respective owners.
You may freely link to this website however ownership of material remains as
stated above.
Contact us:
toyota@hiluxsurf.co.uk
