Greetings all
    Nice innovations there, Shayne. I like it when people think "outside the box". .
    " Time wounds all heels ".
      Originally posted by ShayneJ View Post
      Happy now ?
      Moderately better thank you
      How about some pics of the shock drop bracket from underneath?
      Eat.Sleep.Surf.Repeat.
        ill see what i can do.
        outside the box? well maybe but it is a method
        used all the time in landy circles.
        beauty of the shock mounts is you get to keep
        the original damping property's of the original shocks
        all be it fixed to one setting.
        Same for the ARB sitting at more or less its original
        position relative to the axle.
        and the range rover springs give me the lift while not being
        stiff as a board like as lot of after market tend to be.
        total cost to me sod all as all the bits were laying around in my
        shed if i were to plan it out properly i would have sourced
        some larger box section to accommodate the actuator for the dual
        rate shock but as i tended to leave it on hard anyhow its no big deal
        and as it is done now its an hours work to reverse it all back to stock.
          more shock drop images
            looking a bit less knock kneed after a fiddle with the camber adjusters
              The shock drops mounts make more sense now.
              Which range rover were the springs intended for?
              • #22
                the mounts simply hold the top of the shock 3 inches lower
                than the chassis rail which allows the shock to respond
                as it did when the rest of the suspension was at standard hight
                the odd shape was making best use of the material i had available
                2 by 1 rectangle 3mm wall.
                forming an inverted T with a hole all the way through
                with a captive nut welded at the top.
                allows the shock rubbers to sit one inside and one below
                the T in the same form as they would have
                sat in the flange inside the chassis box.
                the captive nut allows fitting or removing by means of a single
                bolt/washer through the original flange hole.
                the uneven lengths of the cut sections is simply down
                to me being a lazy git if i were doing them for show as it were
                they would be cut to even lengths.
                all that matters is large enough to accommodate the shock rubbers
                to seat correctly and small enough not to foul against the chassis.
                The springs are 90s (late classic) range rover rear HD springs
                known as police spec as they were a factory fit to motorway
                patrol range rovers to cope with constantly carrying
                the vast array of kit and comms gear they used to cram
                in to them.
                on a standard range rover they give just shy of 2 inches of lift
                i have gained somewhat more on the surf.
                point to note they ARE NOT the same diameter as the stock
                springs on the surf the bases are a fraction larger and seat nicely
                but the tops are narrower so do not slide all the way up the inverted cone
                when fitting however after the weight is on them and they have hammered
                over a few pot holes they seat satisfactorily as they have plenty of give.
                • #23
                  shokenore just noticed you are in wilts if you are not to far
                  we could meet up and you can have a proper look
                  i am only just over the border in lambourn.
                  ETA pop round and ill fit your TRD bars and knick you intercooler
                  • #24
                    Lol
                    You probably have more chance of seeing the truck on the A338 up in your neck of the woods atm.
                    The truck is black and shiny(for a wilts truck), with a special forum sticker on the front windscreen, give it a wave
                    The TRD bars and intercooler are all waiting to be fitted, after the truck has been (body)lifted which is waiting to be done after the rear springs which are also on the list........
                    • #25
                      Dont use the 338 much though i do travel the b4000 and newbury rd
                      to n from work. i will keep an eye out.
