I'm just about to remove what's left of the original engine in my surf, ready to drop the replacement in. Don't want to take the gearbox out as well though. If I put a support of some kind under the gearbox will I be ok to lift the engine out or do I need to lift the gearbox slightly to prevent any damage to the splines when disconnecting the engine from the gearbox / torque converter?
It's a 2.4 auto.
I'm hoping it's just going to lift over the threaded studs of the engine mounts, or would it be a better Idea to unbolt the engine mounts completely and lift the engine and the mounts together?
It's a 2.4 auto.
