Go Back   Hilux Surf Forum > HILUX SURF FORUMS - TECHNICAL > 3.0 Turbo Diesel
Thread Tools Display Modes
Old 8th August 2013, 15:07   #1
rory murphy
Default ecu for kzn-130 1994 automatic
hi guys,
i hope one of you can help ,i need an ecu 89661-3d100 for an automatic 1994 hilux surf.
the model is a kd-kzn130w-gkpqt
engine is 1kz-te 2982 cc
frame is kzn 130-9057967
my engine is turning over but i have no power to the glow plug relay (and others apparently) so cannot start.
toyota have discontinued this part, so i'm hoping i don't have to sell my surf over a little e.c.u..
thank you
rory
rory murphy is offline   Reply With Quote
Old 10th August 2013, 01:11   #2
MYLUX
MYLUX's Avatar
Don't know if this is any help,
Just had exactly the same problem - if the glow plug light didn't flash when ign was turned on it wouldn't start. If glow plug lit it would start no problem.
Traced fault to no positive supply to ecu, not saying it's the problem but seems similar.
Just check for power to ecu with ign on, can't remember the pinouts but it's online somewhere.
Smith & Wesson: the first point & click interface
MYLUX is offline   Reply With Quote
Old 10th August 2013, 02:17   #3
andyverran
In the (hopefully) unlikely even it's the ECU, there are companies to repair them. I had my Fiat done a couple of years back...was 295, but got the job done.
andyverran is offline   Reply With Quote
Old 12th August 2013, 14:47   #4
bryanisaoldgit
Default ecu
hi you can get hundreds of ecus for surf,s on flea bay
form as little as 30
the old git
bryanisaoldgit is offline   Reply With Quote
Old 12th August 2013, 14:49   #5
andyverran
good point, I forgot that.
Old 13th August 2013, 00:23   #6
The Boo Crew
Not many for a 3.0 though loads for a 2.4.
The Boo Crew is offline   Reply With Quote
Old 24th August 2013, 07:03   #7
rory murphy
Default ecu
thanks guys, got my e.c.u. repaired 260 quid but back on the road thanks for the suggestions
