How to spot LSD
  • How to spot LSD
    How does one know if ones truck is supposed to have a LSD?
    Most cars/trucks have it marked as a code somewhere but i dunno where to look on Surf.
    Mine is open, tested it one wheel on the grass but to be honest you can usually tell by feel anyway on tight bends.
    Just wanting to find out if there's a LSD in there or if i have to find one for rebuild.
    cheers.
    Axle code ends with a 5 I think
    Sent from the iPad you "lost"
      My 2.4 has a lsd sticker on diff casing
        Give it a lick and then the purple dragon will tell if it's LSD or not
        Hold my beer and watch this
          Yep 294 open 295 LSD. These are the 3.0 codes find them on the vin
          Brian
            My diff code is A02B which is a LSD which is also found on the Soarer occasionally with the same ratios and is much sort after in that community.
              confused now
                confused now
                It may be something to do with the model or year of the Surf which diff was used.
                  These are 2nd gen codes
                  Brian
                    Cheers, i'll have a look later.
                      Well engine bay plate no help, guess I'll crawl under the back when it's less rainy.
                        [QUOTE=popuptoaster;820560]Well engine bay plate no help, guess I'll crawl under the back when it's less rainy.
                        [/QUOTE
                        G294 on that Vin = open diff
                        Brian
                          You have an open rear diff.
                          What are you like at reading wiring diagrams?
                            Cheers, I was looking for 924 rather 294, hey I been working hard!
                            better hunt down a locker then I guess
                            Wiring diagrams not so good, better working with a big handful of wires, managed to wire in monstrous big stereos and modern engines into old cars in the past.
                            (Still can't get me one touch tailgate window working right but I think I know why)
