Old 26th October 2004, 20:02   #1
computingfuture
Guest
Posts: n/a
Default Intercooler on a 2.4
As a few of you who have read some of my other posts will know I am working on puting a top mounted intercooler onto my surf. I have swapped the first intercooler I had for another which looks easier to mount. I have gone to an exhaust shop and got some lengths of stainless cut, bent and the diameter increased to fit. I am waiting for some silicone hoses to be made for me. After that all I have to do is fabricate the brackets and it should be all systems go, I am hoping to get this installed before our trip to wales on sunday. (Fingers Crossed).
I will take some photos when I am doing it and post them here.
Old 26th October 2004, 20:51   #2
MarkR
Why not a front mount? That way you can put in a much larger IC as well as avoid heat soak from your engine. A large FMIC may take slightly longer to pressurize, but once it does your air charge will be much cooler, giving you alot more power at a given level of boost while keeping your EGT lower.
MarkR is offline   Reply With Quote
Old 26th October 2004, 21:20   #3
computingfuture
Guest
Posts: n/a
Quote:
I have an SSR-G with the towing pack so have a massive transmission oil cooler, and AC rad and the main rad. I cant see where I could put even a small one at the front.
Old 27th October 2004, 08:39   #4
lucky
The Godfather
lucky's Avatar
Front mounts are known to cause pretty wicked turbo lag due to the increased pipework.
Andy
99 Land Cruiser 100 Series 4.2TD VX Active
www.landcruiser-rocks.co.uk
www.gloucestershire4x4response .co.uk
www.4x4response.info
lucky is offline   Reply With Quote
Old 27th October 2004, 14:46   #5
rubblebags
Airbourne Division
rubblebags's Avatar
http://www.toyotasurf.asn.au/techsite/performance.htm
dont know if this is any assistance.
Looked at it last night.
Geoff
Rubblebags ([i]Geoff[/i]).
rubblebags is offline   Reply With Quote
Old 27th October 2004, 15:26   #6
MarkR
Even though a FMIC will have a little longer pressurization (lag) time because of the extra piping, it will still provide greater power with lower EGTs than a top mount IC. In other words, while a top mount will give you a much quicker throttle response, a front mount will give you much greater power with much less stress to the engine than a top mount. This is whole point of intercooling in the first place.
Of course, if there is nowhere to fit an intercooler in front, then none of that really matters. A top mount is still much better than no IC. One other benefit of a top mount for off-road applications is that the IC on top will be less vulnerable to trail hazards & mud clogging than a front mount.
Old 27th October 2004, 19:52   #7
computingfuture
Guest
Posts: n/a
update: I got some stainless tubes bent, cut and stretched at a custom exhaust place in exeter yesterday and then went to a company that created custom silicone pipework. I only paid 20 for the stainless but have had to fork out a whopping 170 for the silicone piping I need and have to wait 14 days for it to be fabricated.
All I have to do now is wait, ohh and fabricate some mounts too.
