2.4 surf problem
  • #46
    Is it getting fuel ok? Fuel filter etc ok? Drawing in air? Air in fuel will give smoke
    • #47
      Originally posted by Momos View Post
      Here is where I am I put new glow plug fuse in it started no problem was still smoking a bit but seemed ok it had a slight hesitation when I reved it up then all of a sudden it started to shake and miss and knock really loud my mate just popped down and said it wasn't bottom end it was a diesel knock I got new injectors from peer parts full set for 40 quid he recons they are crap and not helping he says it's defiantly a fueling issue
      Momos, not sure if this helps you at all, but my 2.4 suffered similar symptoms, sounded like the big end, but as you suspect, it was diesel knock. In the end, mine was resolved by replacing a small sensor at the rear of the pump close to the block, held on with 2 allen bolts. Not sure what the sensors name is now, but it adjusts the advance/retard I believe. Banged in a spare one of them off an old pump, and mine was cured.
      Might be worth a look?
      • #48
        You don't happen to know what it is called yeah defo worth a look really struggling with this thing now
        • #49
          Is it a cylender type sensor
          • #50
            Is it the rpm sensor pump speed sensor
            • #51
              I think fuel filter is ok it was drawing air in through manifold but sorted now checked everything all hoses and connections and timing got glow plugs working so starts now just engine shakes and rattles and smokes
              • #52
                Timer control valve
                Found my original thread here;
                http://www.hiluxsurf.co.uk/showthread.php?t=79777
                • #53
                  Only thing id say re tcv is when my failed it threw a red light
                  • #54
                    There is no lights on dash at all when it's running
                    • #55
                      check the secondary heater system in the inlet manifold, chances are thats not connected properly either
                      www.overfab.uk
                      • #56
                        Where about on the inlet manifd is the secondary system
                        • #57
                          The secondary glow system runs on 6 volts the resistor for this resides under the inlet manifold. Also I had better mention that there is an ecu coolant temp sensor there aswell. If this does not work or it is not connected then the secondary system will not operate. Pull the plugs on the ecu,Pins THW and E2 on the ecu should be bridged out and the resistance checked to make sure this is operating correctly.
                          www.overfab.uk
                          • #58
                            Ok I will give that a check thank you
                            • #59
                              I got sick of trying to get surf going so left it alone I am now back at it but still missing
